SteelPE
- Mar 9, 2006
- 2,759
I have a bunch of columns in my structure that are HSS8x8 (1/4-5/16). In looking at the reaction and my beam to column interface, it appears that I may be able to use single angle connections to support my floor girders.
I can use AISC tables 10-10 and 10-11 to calculate the capacity of the single angle connection. I can also calculate the minimum thickness of the tube = 3.09D/Fu. As I am manipulating AISC table 10-10 and 10-11 is there anything else I would need to consider when calculating the strength of the connections?
