gvalves0164
- Jan 3, 2012
- 17
ASME Section VIII DIV 1 Appendix Y states that the rules apply to flat Face, Identical and Non-Identical Flange Pairs where uniform metal to metal contact occurs outside bolt circle. In addition, it states that rules apply for negligible gasket loads (ie. Pressure Energized O-ring Body Seal) HG=0. My question is if spiral wound gaskets are utilized for Body Sealing, do rules apply for using HG*hg in the formula for Flange Thickness Calculations?
