Hi Everybody,
I read most of the Bolt torquing subject here, but I do have a query, does the Flange Material have any influence on the Toruqe valve - the Flange material in the question is Duplex..do the torque value will be same if use Bolt material of A193-B7, and Spiral wound gasket (SS/Graphite)...appreciate a help on this..
Rau
Rau
