Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...This site is truly a marvel. Without a doubt the most comprehensive, friendly and just plain useful resource of its kind..."
Geography
wringwraith1 (Materials)
6 Feb 12 18:01
I have designed a plastic or rubber part, I should say imagined, since the design of the part is the reason I am asking my question, about 75mm long with a multi-contoured outer surface and smooth cylindrical ID about 12-18mm.  I want it strong yet flexible, like a hose with an irregular outer surfce 3 inches long.  What materials should I consider? Where would IM take over as far as volume?
Where do I go to get a bid on the part and how do I ensure my design is not compromised
Pud (Mechanical)
6 Feb 12 19:03
To answer your last question first: It depends on your selling price - and the volume requirements.
Materials: You have a choice of many, at least in the hundreds - what is the application?
You need to talk to your local moulder (molder?) regarding design compromise, but a smooth bore (essential/critical) and a multi-contoured outer is probably possible.
Cheers
H
www.tynevalleyplastics.co.uk
Why be happy when you can be normal?
patprimmer (Publican)
6 Feb 12 21:45
If you want to protect your IP, depending on where you are, take out a patent, register the design, speak to a patent attorney, or have everyone involved sign a non disclosure agreement.
re the technical details, no where near enough information is provide to begin to guess.
What do you mean by flexible?
What do you mean by strong>
What environment will it be exposed to and for how long?
What life do you expect?
How complex is the shape?
What level of precission is required?
Is further processing required, like painting or assembly.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
7 Feb 12 9:58
Wow, you guys are good!  As far as trying to address the material, I would say it would be similar to the hard rubbber used in making an electrical adapter that changes a cord from three prong to two (or vise versa).
That should address both flexibility and strength
The environment would be outdoor weatherable but no additional requirements in terms of excessive heat, or cold.
There are no moving parts and it has no expectations of life cycle - it will likely be lost beforew it becomes unuseable.
The shape would be cylindrical but not necessarily complex.  I envision a few extensions off the body of the part that would be made of the same material but either attached during the molding or attached post-molding.  I guess the complexity would be determined by how these extensions are attached.
Not a high degree of precision.  The parts can have a wide tolerance and they are not required to be identical to each other run-to-run.
If the surface has a relatively smooth feel the part would not require any post painting or coating.  Again, think in terms of the adapter.
I really appreciate the comments.  Do you have any reccommended molders in the Atlanta area?
Steve
MacGyverS2000 (Electrical)
7 Feb 12 10:34
Not sure "flexible" is a term I would use to describe the material in a 2-to-3 prong adapter.  "Ductile" is another I wouldn't expect to use, particularly if you want it to retain its original shape.
Dan - Owner
http://www.Hi-TecDesigns.com
Close Box
Join Eng-Tips® Today!
Join Us             Close
