5050t
Aerospace
- May 9, 2006
- 83
Hello CATIA Gurus!!!
Let me explain my question.
I created a tool that will be used to lay-up carbon.
The actual contact area between the tool and the carbon plies needs a higher surface finish tolerance. In FT&A we use a colour code system to define surface finish tolerances. This contact area is continuous in tangency and simply requires a different colour. I want to avoid selecting individual solid surfaces because this is time consuming.
Is there an easy way to select solid surfaces that are continuous in tangency so I can change the colour? I looked under User Selection Filter tool bar but nothing there to help me.
If anyone knows a good trick, please let all of us know.
Cheers
Peter
Cheers
Peter
