Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...with companys cutting back on training, lack of true support by makers of software, the forums are a great tool in your cyber-toolbox...."
Geography
Pump Speed Vs. Torque Characteristic Curve
ThePunisher (Electrical)
21 Mar 12 8:10
Hi all,
We are dynamically modelling  motor and associated pump in SKM PTW. We ahve obtained the motor characteristic curves with associated inertia.
However, we only managed to obtain the pump inertia and rated torque. We have requested our Mechanical team for the pump speed vs. torque but all they have instead is a pump performance curve that indicates the head and associated flow rates in gallons per minute.
Is it possible to derive the pump speed vs. torque using the pump performance curve? Is the pump speed vs. torque ONLY obtained from the pump manufacturer as an independent curve data?
ione (Mechanical)
21 Mar 12 8:59
T = 5270 * BHP/N
Where:
T = torque
BHP = brake horse power
N = speed (RPM)
Being
BHP = Q *TDH*SG/(3960*efficiency)
Where:
Q = flow (gpm)
TDH = total dynamic head (feet)
SG = pumped fluid specific gravity
Take also a look at the link below
http://centrifugal-pump.org/speed_torque_curve.html
TenPenny (Mechanical)
21 Mar 12 10:15
A good question would be 'what type of pump is this?'  One could assume a centrifugal, but that's not necessarily the case.
Artisi (Mechanical)
21 Mar 12 10:30
http://www.engineeringtoolbox.com/pumps-speed-torque-d_1114.html
or Google "pump speed torque curve"
23 Mar 12 9:26
First of all, thank you for all your replies.
The starting time is computed as a function of several factors: a) motor and pump inertia, b) motor and pump torque vs. speed, c) motor terminal voltage at different currents (during motor acceleration with pump connected)and d) system impendance/voltage drops during acceleration. Some programs like ETAP would perhaps have an built-in typical centrifugal pump torque vs. speed curve and do curve fitting using the pump rated torque and inertia.
Therefore, deriving the speed vs. torque curve is essential.
Artisi (Mechanical)
23 Mar 12 9:44
"Therefore, deriving the speed vs. torque curve is essential."
What is your question?
23 Mar 12 11:15
My question was how to derive a speed vs torque curve from a pump performance curve which was already answered and my thanks for the assistance.
Artisi, the formula for torque in the link you have sent, what is the value of "K"? Are there industry values of K depending on the type of pump? OR is the constant K be obtained from the pump manufacturer to come up with a calculated (estimated) torque vs speed curve?
Back To Forum
Close Box
Join Eng-Tips® Today!
Join Us             Close
