Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I am very impressed with the site and have already recommended it to one of my associates. I was truly impressed with the quickness in which someone actually responded to my question..."
Geography
Nozzle limiting Loads for API-650 Tanks with dia less than 36 meter
khan552 (Mechanical)
21 Apr 12 9:17
I know that Nozzle limiting loads can be calculated as per API-650, Appendix-P. But Appendix-P is applicable for Tanks having diameter greater than 36 meters. Please let me know with API-650 reference, how to calculate Nozzle limiting loads for Tanks having diameter less than 36m.
JStephen (Mechanical)
21 Apr 12 23:04
If I remember correctly, the issue with the 36m was that the technical paper upon which the design is based assumed that thickness was proportional to internal pressure.  This is true with large tanks, not so with small tanks.
You can look into WRC 107 or 297 (and there's a third WRC volume that supplants both, I believe.)  The catch is that these are intended for vessel use, and may not extend to the t/R ratios used in typical tank work.
Close Box
Join Eng-Tips® Today!
Join Us             Close
