ROMEUM2
- Oct 13, 2009
- 24
Hi all,
I have a piping system with a pipe of NPS 32". The specification of the pipe is API 5L (thk 8.7 mm) and i have a corrosion of 1.5 mm.
When i try to do the calculations according WRC 107, i have a problem because my software (microprotol) say me that the ratio d/t is higher than 100.
Anyone knows if i have to take into account the corrosion allowance d/(nominal thk - CA) or we can use the expression d/nominal thickness.
