iain1m
- May 6, 2012
- 1
im running a twin shafted mixer 2 motors , 2 gear boxes thatare coupled together with a shaft, im using one star delta starter with two over loads to start the motors. motor 1 runs ok motor 2 runs ok but when i try to run together it takes out the main breaker, rechecked both are going the correct didrection, checked speed is ok any other ideas
