How to make a Flat pattern
jigotai
3
I have a body in nx 7.5.
And I would like a Flat pattern from it.
How can I do this?
This is the body:
Tim
It appears that your model has compound curvature. If this is the case, Siemens has add-on modules that may be able to flatten it. The modules are Meta-form and/or Fiber Sim (I'm not sure if these are the current names of the modules). Also, you might need to add a blend around the top, the current hard edge might pose a problem for the solver(s).
www.nxjournaling.com
Hm, this is not that simple.
It has compound curvature as Cowski notes, Which means "stretched material" to bend/ unbend. It also has "trimmed edges" which sheet metal "most often" doesn't.
We don't know anything about the material , material properties etc.
I ran a Sheet Metal - Meta Form on it selecting only the outward face. ( i first made it tangent continous, bent objects cannot be bent with perfectly sharp corners...) and used the default values in Meta Form.
Tomas
 http://files.engineering.com/getfile.aspx?folder=35a04021-048a-4d27-b408-c20eef0d162d&file=Window_only.prt
tnx Toost for your reply and the part.
I can't run Meta form because i don't have a license for it.
This is were i was looking for. Tnx again :D
Tim
