How do I created a "softened" corner? 1
mmauldin
Bioengineer
Jul 16, 2004
491
Attached is an NX 7.5 model of what I am trying to do. I want to create a corner that fills in the open area with a surface that is tangent to all of the connecting surfaces. Ultimately I want to use this on solid bodies to soften some external corners. I tried to to use the Transition function, but it keeps insists on crossing the connecting bridge curves and nothing changes when use the toggle direction button.
So first, how do I create the needed sheet body and, secondly, what is the best way to accomplish this on a solid body.
Have you tried to use an Edge Blend with Setbacks (see attached example)?
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
 http://files.engineering.com/getfile.aspx?folder=b673b32e-faa9-43ff-8b6e-bcdb4a706f02&file=Setback_Blend_Example-JRB-1.prt
Exactly what I was looking for. I knew it had to be simple. Thanks.
