I am creating this thread so we may have a summary of everyone's input on how we can go about drilling radial holes in an ASME B16.5 flange.
Some questions I would like to try to address are:
- Does a hole through (Temp or Pressure port) vs. a blind hole (lift lug or lift eye) get handled differently?
- How many holes are allowed, and how to calculate.
- What sized holes?
- I am assuming all holes in this discussion are located centered between bolt holes, and centered axially on the side of the flange.
The goal is also to help address the situation where an ASME B16.36 Orifice flange will not suffice.
Another way to look at this would be, how one would calculate the creation of an ASME B16.36 flange from an ASME B16.5 flange.
Please chime in if you have something to add to this.
Thanks!
- What sized holes?
Thanks!
