Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
[COLOR=blue]Option[/color] [COLOR=blue]Strict[/color] [COLOR=blue]Off[/color]
[COLOR=blue]Imports[/color] System
[COLOR=blue]Imports[/color] System.IO
[COLOR=blue]Imports[/color] NXOpen
[COLOR=blue]Imports[/color] NXOpen.UF
[COLOR=blue]Module[/color] Module1
[COLOR=blue]Sub[/color] Main()
[COLOR=blue]Dim[/color] theSession [COLOR=blue]As[/color] Session [COLOR=blue]=[/color] Session.GetSession()
[COLOR=blue]Dim[/color] ufs [COLOR=blue]As[/color] UFSession [COLOR=blue]=[/color] UFSession.GetUFSession()
[COLOR=blue]Dim[/color] workPart [COLOR=blue]As[/color] Part [COLOR=blue]=[/color] theSession.Parts.Work
[COLOR=blue]Dim[/color] partName [COLOR=blue]As[/color] [COLOR=blue]String[/color] [COLOR=blue]=[/color] Path.GetFileNameWithoutExtension(workPart.FullPath)
[COLOR=green]'directory to output jpegs, change as needed[/color]
[highlight #FCE94F][COLOR=blue]Dim[/color] outputDirectory [COLOR=blue]As[/color] [COLOR=blue]String[/color] [COLOR=blue]=[/color] "C:\temp"[/highlight]
[COLOR=blue]Dim[/color] strPartJpg [COLOR=blue]As[/color] [COLOR=blue]String[/color] [COLOR=blue]=[/color] ""
[COLOR=blue]If[/color] [COLOR=blue]Not[/color] Directory.Exists(outputDirectory) [COLOR=blue]Then[/color]
MsgBox("The specified directory does [COLOR=blue]not[/color] exist, journal will now exit", MsgBoxStyle.Exclamation, outputDirectory [COLOR=blue]&[/color] " [COLOR=blue]not[/color] found")
[COLOR=blue]Exit[/color] [COLOR=blue]Sub[/color]
End [COLOR=blue]If[/color]
[COLOR=blue]Dim[/color] wpModelingView [COLOR=blue]As[/color] ModelingView
[COLOR=blue]For[/color] [COLOR=blue]Each[/color] wpModelingView [COLOR=blue]In[/color] workPart.ModelingViews
workPart.Views.WorkView.Orient(wpModelingView.Name, View.ScaleAdjustment.Fit)
strPartJpg [COLOR=blue]=[/color] partName [COLOR=blue]&[/color] "_" [COLOR=blue]&[/color] wpModelingView.Name [COLOR=blue]&[/color] ".jpg"
strPartJpg [COLOR=blue]=[/color] Path.Combine(outputDirectory, strPartJpg)
ufs.Disp.CreateImage(strPartJpg, UFDisp.ImageFormat.Jpeg, UFDisp.BackgroundColor.White)
[COLOR=blue]Next[/color]
End [COLOR=blue]Sub[/color]
[COLOR=blue]Public[/color] [COLOR=blue]Function[/color] GetUnloadOption(ByVal dummy [COLOR=blue]As[/color] [COLOR=blue]String[/color]) [COLOR=blue]As[/color] [COLOR=blue]Integer[/color]
[COLOR=green]'Unloads the image when the NX session terminates[/color]
GetUnloadOption [COLOR=blue]=[/color] NXOpen.Session.LibraryUnloadOption.AtTermination
End [COLOR=blue]Function[/color]
End [COLOR=blue]Module[/color]
berri2 said:Is there any way to add these JPEG shots to an HTML or a PDF file directly?
[COLOR=green]'NXJournaling.com[/color]
[COLOR=green]'March 21, 2012[/color]
[COLOR=green]'Journal purpose: export shaded model views to a pdf file[/color]
[COLOR=green]' the journal creates an "A" or "A4" size sheet for each model view, places[/color]
[COLOR=green]' the view on the sheet and scales it to fit. The journal then exports all[/color]
[COLOR=green]' the sheets to the specified pdf file[/color]
[COLOR=blue]Imports[/color] System.Windows.Forms
[COLOR=blue]Imports[/color] System.Collections
[COLOR=blue]Module[/color] Export_Shaded_pdf
[COLOR=blue]Dim[/color] ufs [COLOR=blue]As[/color] UF.UFSession [COLOR=blue]=[/color] UF.UFSession.GetUFSession()
[COLOR=blue]Dim[/color] pdfSheets [COLOR=blue]As[/color] [COLOR=blue]New[/color] ArrayList
[COLOR=blue]Dim[/color] markId1 [COLOR=blue]As[/color] Session.UndoMarkId
markId1 [COLOR=blue]=[/color] theSession.SetUndoMark(Session.MarkVisibility.Visible, "Start")
theSession.SetUndoMarkName(markId1, "pdf_sheets")
[COLOR=blue]Dim[/color] pdfSheet [COLOR=blue]As[/color] Drawings.DrawingSheet
[COLOR=blue]Dim[/color] outputFileName(1) [COLOR=blue]As[/color] [COLOR=blue]String[/color]
[COLOR=blue]Dim[/color] pdfFile [COLOR=blue]As[/color] [COLOR=blue]String[/color]
[COLOR=green]'create new sheet for view[/color]
pdfSheet [COLOR=blue]=[/color] CreateSheet()
pdfSheet.SetName(wpModelingView.Name)
[COLOR=green]'add view to new sheet[/color]
AddView(wpModelingView, pdfSheet)
pdfSheets.Add(pdfSheet)
outputFileName(0) [COLOR=blue]=[/color] OutputPath()
outputFileName(1) [COLOR=blue]=[/color] Path.GetFileNameWithoutExtension(workPart.FullPath) [COLOR=blue]&[/color] ".pdf"
pdfFile [COLOR=blue]=[/color] Path.Combine(outputFileName(0), outputFileName(1))
[COLOR=blue]If[/color] My.Computer.FileSystem.FileExists(pdfFile) [COLOR=blue]Then[/color]
My.Computer.FileSystem.DeleteFile(pdfFile)
[COLOR=green]'output new sheets to pdf[/color]
[COLOR=blue]Try[/color]
[COLOR=blue]Call[/color] CreatePDF(pdfFile)
[COLOR=blue]Catch[/color] ex [COLOR=blue]As[/color] UnauthorizedAccessException
MessageBox.Show("You [COLOR=blue]do[/color] [COLOR=blue]not[/color] have permission [COLOR=blue]to[/color] write [COLOR=blue]to[/color] this directory", "PDF file creation error", MessageBoxButtons.OK, MessageBoxIcon.Error)
[COLOR=blue]Catch[/color] ex [COLOR=blue]As[/color] ApplicationException
MessageBox.Show(ex.Message, "PDF file creation error", MessageBoxButtons.OK, MessageBoxIcon.Error)
End [COLOR=blue]Try[/color]
[COLOR=green]'optional: delete pdf sheets[/color]
[COLOR=blue]Dim[/color] markId2 [COLOR=blue]As[/color] Session.UndoMarkId
markId2 [COLOR=blue]=[/color] theSession.SetUndoMark(Session.MarkVisibility.Visible, "Delete")
[COLOR=blue]Dim[/color] objects1(pdfSheets.Count [COLOR=blue]-[/color] 1) [COLOR=blue]As[/color] NXObject
[COLOR=blue]For[/color] i [COLOR=blue]As[/color] [COLOR=blue]Integer[/color] [COLOR=blue]=[/color] 0 [COLOR=blue]To[/color] pdfSheets.Count [COLOR=blue]-[/color] 1
objects1(i) [COLOR=blue]=[/color] pdfSheets.Item(i)
pdfSheets.Clear()
[COLOR=blue]Dim[/color] nErrs1 [COLOR=blue]As[/color] [COLOR=blue]Integer[/color]
nErrs1 [COLOR=blue]=[/color] theSession.UpdateManager.AddToDeleteList(objects1)
[COLOR=blue]Dim[/color] notifyOnDelete2 [COLOR=blue]As[/color] [COLOR=blue]Boolean[/color]
notifyOnDelete2 [COLOR=blue]=[/color] theSession.Preferences.Modeling.NotifyOnDelete
[COLOR=blue]Dim[/color] nErrs2 [COLOR=blue]As[/color] [COLOR=blue]Integer[/color]
nErrs2 [COLOR=blue]=[/color] theSession.UpdateManager.DoUpdate(markId2)
[COLOR=blue]Public[/color] [COLOR=blue]Function[/color] CreateSheet() [COLOR=blue]As[/color] Drawings.DrawingSheet
[COLOR=green]' ----------------------------------------------[/color]
[COLOR=green]' Menu: Insert->Sheet...[/color]
[COLOR=green]'Dim markId1 As Session.UndoMarkId[/color]
[COLOR=green]'markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Start")[/color]
[COLOR=blue]Dim[/color] nullDrawings_DrawingSheet [COLOR=blue]As[/color] Drawings.DrawingSheet [COLOR=blue]=[/color] [COLOR=blue]Nothing[/color]
[COLOR=blue]Dim[/color] drawingSheetBuilder1 [COLOR=blue]As[/color] Drawings.DrawingSheetBuilder
drawingSheetBuilder1 [COLOR=blue]=[/color] workPart.DrawingSheets.DrawingSheetBuilder(nullDrawings_DrawingSheet)
drawingSheetBuilder1.Option [COLOR=blue]=[/color] Drawings.DrawingSheetBuilder.SheetOption.StandardSize
[COLOR=green]'start with 1:1 scale sheet, view will be scaled to fit later[/color]
drawingSheetBuilder1.ScaleNumerator [COLOR=blue]=[/color] 1.0
drawingSheetBuilder1.ScaleDenominator [COLOR=blue]=[/color] 1.0
[COLOR=blue]If[/color] workPart.PartUnits [COLOR=blue]=[/color] Part.Units.Inches [COLOR=blue]Then[/color]
drawingSheetBuilder1.Units [COLOR=blue]=[/color] Drawings.DrawingSheetBuilder.SheetUnits.English
[COLOR=green]'insert standard letter size sheet[/color]
drawingSheetBuilder1.Height [COLOR=blue]=[/color] 8.5
drawingSheetBuilder1.Length [COLOR=blue]=[/color] 11.0
[COLOR=blue]Else[/color] [COLOR=green]'metric unit file[/color]
drawingSheetBuilder1.Units [COLOR=blue]=[/color] Drawings.DrawingSheetBuilder.SheetUnits.Metric
[COLOR=green]'insert standard A4 size sheet[/color]
drawingSheetBuilder1.Height [COLOR=blue]=[/color] 210
drawingSheetBuilder1.Length [COLOR=blue]=[/color] 297
[COLOR=green]'sheetLength = drawingSheetBuilder1.Length[/color]
[COLOR=green]'sheetHeight = drawingSheetBuilder1.Height[/color]
drawingSheetBuilder1.ProjectionAngle [COLOR=blue]=[/color] Drawings.DrawingSheetBuilder.SheetProjectionAngle.Third
pdfSheet [COLOR=blue]=[/color] drawingSheetBuilder1.Commit()
[COLOR=green]'theSession.SetUndoMarkName(markId1, "##01Sheet")[/color]
drawingSheetBuilder1.Destroy()
[COLOR=blue]Return[/color] pdfSheet
[COLOR=blue]Public[/color] [COLOR=blue]Sub[/color] AddView(ByVal view [COLOR=blue]As[/color] ModelingView, [COLOR=blue]ByVal[/color] sheet [COLOR=blue]As[/color] Drawings.DrawingSheet)
[COLOR=green]' Menu: Insert->View->Base...[/color]
[COLOR=green]'Dim markId3 As Session.UndoMarkId[/color]
[COLOR=green]'markId3 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Start")[/color]
sheet.Open()
[COLOR=blue]Dim[/color] nullDrawings_BaseView [COLOR=blue]As[/color] Drawings.BaseView [COLOR=blue]=[/color] [COLOR=blue]Nothing[/color]
[COLOR=blue]Dim[/color] baseViewBuilder1 [COLOR=blue]As[/color] Drawings.BaseViewBuilder
baseViewBuilder1 [COLOR=blue]=[/color] workPart.DraftingViews.CreateBaseViewBuilder(nullDrawings_BaseView)
baseViewBuilder1.SelectModelView.SelectedView [COLOR=blue]=[/color] view
[COLOR=green]'theSession.SetUndoMarkName(markId3, "Base View Dialog")[/color]
baseViewBuilder1.Style.ViewStyleBase.Part [COLOR=blue]=[/color] workPart
baseViewBuilder1.Style.ViewStyleBase.PartName [COLOR=blue]=[/color] workPart.FullPath
[COLOR=blue]Dim[/color] arrangement1 [COLOR=blue]As[/color] Assemblies.Arrangement [COLOR=blue]=[/color] workPart.ComponentAssembly.ActiveArrangement
baseViewBuilder1.Style.ViewStyleBase.Arrangement.SelectedArrangement [COLOR=blue]=[/color] arrangement1
baseViewBuilder1.Style.ViewStyleShading.RenderingStyle [COLOR=blue]=[/color] Preferences.ShadingRenderingStyleOption.FullyShaded
[COLOR=green]'place the view in the center of the sheet[/color]
[COLOR=blue]Dim[/color] point1 [COLOR=blue]As[/color] Point3d [COLOR=blue]=[/color] [COLOR=blue]New[/color] Point3d(sheet.Length [COLOR=blue]/[/color] 2, sheet.Height [COLOR=blue]/[/color] 2, 0.0)
baseViewBuilder1.Placement.Placement.SetValue(Nothing, workPart.Views.WorkView, point1)
[COLOR=blue]Dim[/color] baseView1 [COLOR=blue]As[/color] Drawings.BaseView
baseView1 [COLOR=blue]=[/color] baseViewBuilder1.Commit()
[COLOR=green]'theSession.SetUndoMarkName(markId3, "Base View")[/color]
[COLOR=blue]Dim[/color] viewSize(3) [COLOR=blue]As[/color] [COLOR=blue]Double[/color]
[COLOR=green]'retrieve the size of the view[/color]
ufs.Draw.AskViewBorders(baseView1.Tag, viewSize)
[COLOR=blue]Dim[/color] viewLength [COLOR=blue]As[/color] [COLOR=blue]Double[/color] [COLOR=blue]=[/color] viewSize(2) [COLOR=blue]-[/color] viewSize(0)
[COLOR=blue]Dim[/color] viewHeight [COLOR=blue]As[/color] [COLOR=blue]Double[/color] [COLOR=blue]=[/color] viewSize(3) [COLOR=blue]-[/color] viewSize(1)
[COLOR=green]'change scale of view so that it fits on 90% of the selected sheet size[/color]
baseView1.Style.General.Scale [COLOR=blue]=[/color] Math.Min((sheet.Length [COLOR=blue]*[/color] 0.9) [COLOR=blue]/[/color] viewLength, (sheet.Height [COLOR=blue]*[/color] 0.9) [COLOR=blue]/[/color] viewHeight)
baseView1.Commit()
baseViewBuilder1.Destroy()
[COLOR=blue]Public[/color] [COLOR=blue]Sub[/color] CreatePDF(ByVal outputFile [COLOR=blue]As[/color] [COLOR=blue]String[/color])
[COLOR=blue]Dim[/color] printPDFBuilder1 [COLOR=blue]As[/color] PrintPDFBuilder
printPDFBuilder1 [COLOR=blue]=[/color] workPart.PlotManager.CreatePrintPdfbuilder()
printPDFBuilder1.Scale [COLOR=blue]=[/color] 1.0
printPDFBuilder1.Action [COLOR=blue]=[/color] PrintPDFBuilder.ActionOption.Native
printPDFBuilder1.Colors [COLOR=blue]=[/color] PrintPDFBuilder.Color.BlackOnWhite
printPDFBuilder1.Size [COLOR=blue]=[/color] PrintPDFBuilder.SizeOption.ScaleFactor
printPDFBuilder1.Units [COLOR=blue]=[/color] workPart.PartUnits
[COLOR=green]'If units = 0 Then[/color]
[COLOR=green]' printPDFBuilder1.Units = PrintPDFBuilder.UnitsOption.English[/color]
[COLOR=green]'Else[/color]
[COLOR=green]' printPDFBuilder1.Units = PrintPDFBuilder.UnitsOption.Metric[/color]
[COLOR=green]'End If[/color]
printPDFBuilder1.XDimension [COLOR=blue]=[/color] pdfSheets.Item(1).Height
printPDFBuilder1.YDimension [COLOR=blue]=[/color] pdfSheets.Item(1).Length
printPDFBuilder1.OutputText [COLOR=blue]=[/color] PrintPDFBuilder.OutputTextOption.Polylines
printPDFBuilder1.RasterImages [COLOR=blue]=[/color] [COLOR=blue]True[/color]
printPDFBuilder1.ImageResolution [COLOR=blue]=[/color] PrintPDFBuilder.ImageResolutionOption.Medium
printPDFBuilder1.Append [COLOR=blue]=[/color] [COLOR=blue]True[/color]
printPDFBuilder1.AddWatermark [COLOR=blue]=[/color] [COLOR=blue]False[/color]
[COLOR=blue]Dim[/color] sheets1(pdfSheets.Count [COLOR=blue]-[/color] 1) [COLOR=blue]As[/color] NXObject
[COLOR=green]'Dim drawingSheet1 As Drawings.DrawingSheet = CType(dwg, Drawings.DrawingSheet)[/color]
sheets1(i) [COLOR=blue]=[/color] pdfSheets.Item(i)
[COLOR=green]'sheets1(0) = drawingSheet1[/color]
printPDFBuilder1.SourceBuilder.SetSheets(sheets1)
printPDFBuilder1.Filename [COLOR=blue]=[/color] outputFile
[COLOR=green]'printPDFBuilder1.Filename = "C:\Temp\test.pdf"[/color]
[COLOR=blue]Dim[/color] nXObject1 [COLOR=blue]As[/color] NXObject
nXObject1 [COLOR=blue]=[/color] printPDFBuilder1.Commit()
printPDFBuilder1.Destroy()
[COLOR=blue]Function[/color] OutputPath()
[COLOR=green]'Requires:[/color]
[COLOR=green]' Imports System.IO[/color]
[COLOR=green]' Imports System.Windows.Forms[/color]
[COLOR=green]'if the user presses OK on the dialog box, the chosen path is returned[/color]
[COLOR=green]'if the user presses cancel on the dialog box, 0 is returned[/color]
[COLOR=blue]Dim[/color] strLastPath [COLOR=blue]As[/color] [COLOR=blue]String[/color]
[COLOR=blue]Dim[/color] strOutputPath [COLOR=blue]As[/color] [COLOR=blue]String[/color]
[COLOR=green]'Key will show up in HKEY_CURRENT_USER\Software\VB and VBA Program Settings[/color]
[COLOR=green]'Get the last path used from the registry[/color]
strLastPath [COLOR=blue]=[/color] GetSetting("NX journal", "Export pdf", "ExportPath")
[COLOR=green]'msgbox("Last Path: " & strLastPath)[/color]
[COLOR=blue]Catch[/color] e [COLOR=blue]As[/color] ArgumentException
[COLOR=blue]Catch[/color] e [COLOR=blue]As[/color] Exception
msgbox(e.GetType.ToString)
[COLOR=blue]Finally[/color]
[COLOR=blue]Dim[/color] FolderBrowserDialog1 [COLOR=blue]As[/color] [COLOR=blue]New[/color] FolderBrowserDialog
[COLOR=green]' Then use the following code to create the Dialog window[/color]
[COLOR=green]' Change the .SelectedPath property to the default location[/color]
[COLOR=blue]With[/color] FolderBrowserDialog1
[COLOR=green]' Desktop is the root folder in the dialog.[/color]
.RootFolder [COLOR=blue]=[/color] Environment.SpecialFolder.Desktop
[COLOR=green]' Select the D:\home directory on entry.[/color]
[COLOR=blue]If[/color] Directory.Exists(strLastPath) [COLOR=blue]Then[/color]
.SelectedPath [COLOR=blue]=[/color] strLastPath
.SelectedPath [COLOR=blue]=[/color] Environment.SpecialFolder.MyDocuments
[COLOR=green]' Prompt the user with a custom message.[/color]
.Description [COLOR=blue]=[/color] "Select the directory to export .pdf file"
[COLOR=blue]If[/color] .ShowDialog [COLOR=blue]=[/color] DialogResult.OK [COLOR=blue]Then[/color]
[COLOR=green]' Display the selected folder if the user clicked on the OK button.[/color]
OutputPath [COLOR=blue]=[/color] .SelectedPath
[COLOR=green]' save the output folder path in the registry for use on next run[/color]
SaveSetting("NX journal", "Export pdf", "ExportPath", .SelectedPath)
[COLOR=green]'user pressed 'cancel', exit the subroutine[/color]
OutputPath [COLOR=blue]=[/color] 0
End [COLOR=blue]With[/color]
