Trevorsg80
- Jul 2, 2012
- 20
My question is that I have a horizontal storage tank with one floating saddle on teflon pads. These tanks have a high cyclical load from thermal expansion so it will need to allow some flex in it. This will be in a pharmaceutical clean room with a lot of water and steam. What I need help with is designing or purchasing a "skirt" or "shroud" that will prevent water from getting under the saddle and around the bearing pad. I also don't want the water going around the anchor bolts. I can't have any microbial growth going on here and it will be too difficult to clean. Is there a company out there who can make this for me or is there an example of a design that I go reference?
I've attached an image of the tank for your reference.
Thank you.
Thank you.
