Macro Catia with holes
gerlado
23
ES
Hi friends
I try to find a macro that can you read me the total number of holes of a catia part
The code is the follow:
Sub CATMain()
Dim partDocument1 As Document
Set partDocument1 = CATIA.ActiveDocument
Dim part1 As Part
Set part1 = partDocument1.Part
Dim bodies1 As Bodies
Set bodies1 = part1.Bodies
Dim body1 As Body
Set body1 = bodies1.Item("PartBody")
Dim shapes1 As Shapes
Set shapes1 = body1.Shapes
dim selection1 as selection
set selection1=CATIA.activedocument.selection
selection1.clear
for i = 1 to shapes1.count
selection1.add shapes1.Item(i)
NEXT
Dim xSelObj() As Variant
Dim xObj As Variant
Dim n as Integer
Dim myObj As AnyObject
Dim nCount As Integer
nCount = 0
for n= 0 to shapes1.count
On Error Resume Next
Set myObj = selection1.FindObject("CATIAHole")
ReDim Preserve xSelObj(nCount)
Set xSelObj(nCount) = myObj
nCount = nCount + 1
next
' Listing holes
Dim sList As String
Dim nI As Integer
'Loop for message
For nI =0 To ncount-3
dim referenceX as reference
Set referenceX = part1.CreateReferenceFromObject(xSelObj(nI))
Next
part1.Update
End Sub
My Problem is that this macro can´t read the hole made with a rectangular or circullar pateerm
If it posible, someone can you help me whit this
And How can export the information of this hole (Thread, length...etc)
Thank you very much for all
to find patterns in partdesign:
Set myObj = selection1.FindObject("CATIAPattern")
msgbox myObj.itemtocopy.name <- it's item's name, e.g. Hole.1, If You have array of Holes You can easily check if ItemToCopy refers to Holes or other Shapes
to get parameters:
set params = part1.parameters
msgbox params.item(1).name <-thats the way You can list all Your parameters.
I would be glad (and Author probably too) if anyone show how to get list of parameters related to specified object, eg Shape
I believe there is a similar thread in the forum. Anyway...catscript...and of course, you need to modify according to your needs.
Language="VBSCRIPT"
Sub CATMain()
Dim oPartDoc As PartDocument
Dim oBody As Body
Dim oHole As Hole
Dim i As Integer
Dim selection1 As Selection
Dim selection2 As Selection
Dim oHoleName As HoleName
Dim oHoleType As HoleType
CATIA.DisplayFileAlerts = False
Dim Message, Style, Title, Response, MyString
Message = ("You must have a temp folder in your C drive " &_
""&(chr(13))&_
" Do you want to continue ?")
Style = vbYesNo + vbDefaultButton2 'Define buttons.
Title = "Extract holes parameters to text file"
Response = MsgBox(Message, Style, Title)
If Response = vbYes Then ' User chose Yes.
MyString = "Yes"
Else
If Response = vbNo Then
MyString = "No"
Exit Sub
End If
End If
Set document = CATIA.ActiveDocument
Set filesys = CATIA.FileSystem
crlf = chr(10)
filename = "c:\temp\Holes_parameters_of_"&document.Name&".txt"
if filesys.FileExists(filename) Then
filesys.DeleteFile(filename)
End If
Set file = filesys.CreateFile(filename,True)
Set stream = file.OpenAsTextStream("ForWriting")
err=0
iHoleInSelection = True
Set oPartDoc = CATIA.ActiveDocument
Set oBody = oPartDoc.Part.Bodies.Item("PartBody")
Set selection1 = oPartDoc.Selection
selection1.Search "(Name=PartBody* & CATPrtSearch.BodyFeature),all"
Set selection2 = oPartDoc.Selection
selection2.Search "Type=Hole,sel"
stream.write("Crt_no"&" "&"Hole_Name"&" "&"Hole_Dia"&" "&"Hole_Type"&crlf) 'first line in output file
For i=1 To selection2.Count
Set oHole = selection2.Item(i).Value
Set oHoleName = selection2.Item(i).Value
Set oHoleType = selection2.Item(i).Value
MsgBox CStr(oHoleName.Name) & " " & " " & "Diameter=" & CStr(oHole.Diameter.Value) & " " & "Type=" & CStr(oHole.Type)
stream.write(i&" "&oHoleName.Name&" "&oHole.Diameter.Value&" "&oHole.Type&crlf)
Next
End Sub
Fernando
Hello Ferdo
Thank you very much for your message
I found it very useful
Elsewhere
I still can not solve the problem of the pattern rectangullar and circular, because the way of lukaszs doesn´t work me.
Could you help me with the media into the holes counter?
Thank you very much
Ok
thank you very much
It will look about
thank you very much
