Catia macro to replace Property with UserRefProperties in the complete tree 1
eperichon
Aerospace
CH
I am new in VBA and try to modify a code that change the instance name, in order that this code also change every catia properties of each parts, products ... in the complete tree. In fact I want that this instance rename code also change component DescriptionRef and Nomenclature with UserRefProperties that exists in each components.
I have the following code found on internet :
Code:
[COLOR=#4E9A06]'********************************************************
'By MarkAF, some code borrowed from forums
'********************************************************[/color]
Public oList As Variant
Option Explicit
Sub CATMain()
On Error Resume Next
[COLOR=#4E9A06]'Declarations[/color]
Dim oTopDoc As Document
Dim oTopProd As ProductDocument
Dim oCurrentProd As Product
Dim n As Integer
[COLOR=#4E9A06]'Check if the active document is an assembly, else exit[/color]
Set oTopDoc = CATIA.ActiveDocument
If oTopDoc Is Nothing Then
        MsgBox "Must have an assembly open"
        Exit Sub
End If
If Right(oTopDoc.Name, 7) <> "Product" Then
    MsgBox "Active document should be a product"
    Exit Sub
End If
Set oCurrentProd = oTopDoc.Product
Set oList = CreateObject("Scripting.dictionary")
CATIA.StatusBar = "Working On" & " " & oCurrentProd.Name
Call RenameSingleLevel(oCurrentProd)    [COLOR=#4E9A06]'Call the subroutine, it is a recursive loop[/color]
CATIA.StatusBar = "Done"
End Sub
Private Sub RenameSingleLevel(ByRef oCurrentProd As Product)
[COLOR=#4E9A06]'More declarations[/color]
Dim ItemToRename As Product
Dim ToRenamePartNumber As String
Dim ToRenamePartDescription As String
Dim NumberOfItems As Long
Dim RenameArray(2000) As String
Dim i As Integer
Dim j As Integer
Dim k As Integer
Set oCurrentProd = oCurrentProd.ReferenceProduct    [COLOR=#4E9A06]'You have to work with the "ReferenceProduct" object[/color]NumberOfItems = oCurrentProd.Products.Count
[COLOR=#4E9A06]'Run through this loop once, to set everything to a dummy name, to avoid naming conflicts[/color]
For i = 1 To NumberOfItems                             [COLOR=#4E9A06]'Cycle through the assembly's children[/color]
    Set ItemToRename = oCurrentProd.Products.Item(i)    [COLOR=#4E9A06]'Declare which item we are working on[/color]
    ToRenamePartNumber = ItemToRename.PartNumber           [COLOR=#4E9A06] 'Get the Part Number[/color]
    If InStr(ToRenamePartNumber, "-_") <> 0 Then         [COLOR=#4E9A06]'Check for KT #'s, should exist only in CGRs[/color]
        ToRenamePartNumber = Left(ToRenamePartNumber, (InStr(ToRenamePartNumber, "-_") - 1))
    End If
    RenameArray(i) = ToRenamePartNumber                 [COLOR=#4E9A06]'Building the list of part names for the numbering loop[/color]
    k = 0                                               [COLOR=#4E9A06]'Numbering Loop[/color]
    For j = 1 To i                                      [COLOR=#4E9A06]'This loop checks and sets the instance number[/color]
        If RenameArray(j) = ToRenamePartNumber Then
            k = k + 1
        End If
    Next
    CATIA.StatusBar = ItemToRename.Name & " > " & ToRenamePartNumber & "." & k
    ItemToRename.Name = ToRenamePartNumber & "TEMP." & k    [COLOR=#4E9A06]'Set the new instance name, to a TEMP dummy value[/color]
Next
[COLOR=#4E9A06]'Run through this loop to set the name finally, then the recursion call[/color]
    ToRenamePartNumber = ItemToRename.PartNumber        [COLOR=#4E9A06]'Toggle these two lines for testing[/color]
    [COLOR=#EF2929]ItemToRename.DescriptionInst = ItemToRename.UserRefProperties.Item("Designation").Value
    ItemToRename.Nomenclature = ItemToRename.UserRefProperties.Item("codeGPAO").Value
    oCurrentProd.DescriptionRef = oCurrentProd.UserRefProperties.Item("Designation").Value
    oCurrentProd.Nomenclature = oCurrentProd.UserRefProperties.Item("codeGPAO").Value[/color]
    [COLOR=#4E9A06]'ItemToRename.DescriptionInst = "CC1"
    'ItemToRename.Nomenclature = "BB1"
    'oCurrentProd.DescriptionRef = "CC2"
    'oCurrentProd.Nomenclature = "BB2"[/color]
    k = 0
    For j = 1 To i
            k = k + 1
        End If
    Next
    ItemToRename.Name = ToRenamePartNumber & "." & k    [COLOR=#4E9A06]'Set the new instance name final[/color]
    If ItemToRename.Products.Count <> 0 Then        [COLOR=#4E9A06]'Recursive Call[/color]
        If oList.exists(ItemToRename.PartNumber) Then GoTo Finish
        If ItemToRename.PartNumber = ItemToRename.ReferenceProduct.Parent.Product.PartNumber Then oList.Add ItemToRename.PartNumber, 1
        Call RenameSingleLevel(ItemToRename)
    End If
Finish:
Next
End Sub
In fact the code works, but only for the products inside the complete tree (red line were added). It doesn't work for the parts inside this one... WHY ??? But if I only put some text between "...", it works for every components inside the tree. i don't understand, I need some help please. Thank you.
I think you have to use the "GetItem" method in order to call the UserRefProperties by name. Using the "Item()" method it wants an index number, such as .Item(1) or .Item(i) where 'i' is an integer.
So, each line of code would look like this:
ItemToRename.DescriptionInst = ItemToRename.UserRefProperties.GetItem("Designation").Value
This is coming from the Dassault VBA help file. Hope that helps.
Mark
Hello Mark,
Thank you for your answer. I have just tried to modify the code, but I have still the same issue. It works on all the products of the tree, but it doesn't work for the parts inside the tree.
Code:
Option Explicit
Sub CATMain()
Dim n As Integer
        Exit Sub
End If
    Exit Sub
End If
End Sub
Dim i As Integer
Dim j As Integer
Dim k As Integer
Set oCurrentProd = oCurrentProd.ReferenceProduct    [COLOR=#4E9A06]'You have to work with the "ReferenceProduct"[/color]
objectNumberOfItems = oCurrentProd.Products.Count
    ToRenamePartNumber = ItemToRename.PartNumber            [COLOR=#4E9A06]'Get the Part Number[/color]
    End If
    For j = 1 To i                                      'This loop checks and sets the instance number
            k = k + 1
        End If
    Next
Next
    [COLOR=#4E9A06]'ItemToRename.DescriptionInst = ItemToRename.UserRefProperties.Item("Designation").Value
    'ItemToRename.Nomenclature = ItemToRename.UserRefProperties.Item("codeGPAO").Value
    'oCurrentProd.DescriptionRef = oCurrentProd.UserRefProperties.Item("Designation").Value
    'oCurrentProd.Nomenclature = oCurrentProd.UserRefProperties.Item("codeGPAO").Value[/color]
    [COLOR=#EF2929]ItemToRename.DescriptionRef = ItemToRename.UserRefProperties.GetItem("Designation").Value
    ItemToRename.Nomenclature = ItemToRename.UserRefProperties.GetItem("codeGPAO").Value[/color]
    [COLOR=#729FCF]oCurrentProd.DescriptionRef = oCurrentProd.UserRefProperties.GetItem("Designation").Value
    oCurrentProd.Nomenclature = oCurrentProd.UserRefProperties.GetItem("codeGPAO").Value[/color]
    k = 0
    For j = 1 To i
            k = k + 1
        End If
    Next
    End If
Finish:
Next
End Sub
For the blue lines, it works well for every products and sub-products. But I think that the red lines don't work because no parts properties were change...
Is it because ItemToRename is define as Products ??
Code:
Thank you.
Ok, I finally had a bit of time to look at this. Sorry it's taken a while.
So, there's a few things going on. I found that for this, instead of accessing the DescriptionRef property directly from the Product object, you have to access it through the ReferenceProduct object. I don't know why...perhaps someone else can enlighten us [sunshine]
Your line of code to transfer the properties should then look like this:
ItemToRename.DescriptionRef = ItemToRename.ReferenceProduct.UserRefProperties.GetItem("Designation").Value
ItemToRename.Nomenclature = ItemToRename.ReferenceProduct.UserRefProperties.GetItem("codeGPAO").Value
Also, for your purposes, there's a big chunk of code that you do not need. The whole section that starts with the comment "Run through this loop once" can be deleted, it's only to deal with instance names. The section with the k counter can be deleted, since it's also for the instance name.
Last point, this code is not optimized for larger assemblies. If it comes across a part or assembly again, it will work on that part or assembly again. In some macros I have worked to avoid this, but I don't have it at my fingertips right now.
The most fascinating thing to me is the recursive call. It kind of boggled my mind for a while. Recursions are well worth studying...call stacks and all that. I'm sure that what I came up with is about as simple as it gets, but it works for this purpose.
Here's what it looks like once I got it cleaned up a bit:
Code:
Option Explicit
Sub CATMain()
'Declarations
Dim n As Integer
        Exit Sub
End If
    Exit Sub
End If
Call RenameSingleLevel(oCurrentProd)    'Call the subroutine, it is a recursive loop
End Sub
'More declarations
Dim i As Integer
Set oCurrentProd = oCurrentProd.ReferenceProduct    'You have to work with the "ReferenceProduct"
    ToRenamePartNumber = ItemToRename.PartNumber        'Toggle these two lines for testing
    CATIA.StatusBar = "Working on " & ItemToRename.Name
'This section is the recursive call. If this level has children products, then it will step down to that level.
    End If
Finish:
Next
End Sub
Cheers,
Mark
