CATIA Macro : Extracting Point Coordinate in a Sub Geometrical Set 1
d2z
Automotive
May 1, 2013
6
Hi all
i'm new in catia macro programming. what i'm working on now is extracting points coordinates from CATPart.
my problem now is how to extract point in a sub geometrical set.
refer picture below (point 1 in geometrical set.2)
i only manage to extract point from 'parent geometrical set' (geometrical set.1)
here is my code for now. do comment what i can improve the current code. i have really basic programming skill.
tq in advance :)
Code:
Sub CATMain()
Dim ActDoc As Object
Set ActDoc = CATIA.ActiveDocument
Dim part1 As Object
Set part1 = ActDoc.Part
Dim hybridBodies1 As Object
Set hybridBodies1 = part1.HybridBodies
For geometSet = 1 To hybridBodies1.Count
    Dim hybridBody1 As Object
    Set hybridBody1 = hybridBodies1.Item(geometSet)
    Dim hybridShapes1 As Object
    Set hybridShapes1 = hybridBody1.HybridShapes
	    For geometElem = 1 To hybridShapes1.Count
    	    Dim point1
        	Set point1 = hybridShapes1.Item(geometElem)
			On Error Resume Next
    	    Dim coordArray(2)
	        Dim sel As Object
    	    Set sel = ActDoc.selection
	        sel.Add (point1)
    	    sel.Clear
point1.GetCoordinates coordArray
p=0
msgbox "Point: " & point1.Name & vbNewLine & "X : " & coordArray(p) & vbNewLine & "Y:  " & coordArray(p+1)  & vbNewLine & "Z: " & coordArray(p+2)
p + 1
Next 'geometElem
Next 'geometSet
End Sub
Hi
Code:
Sub CATMain()
Dim iAnswer
iAnswer = MsgBox ("You need to select first your points" & Chr(10) & "Click OK if you already done the selection or Cancel to EXIT", vbOKCancel)
if iAnswer = vbCancel Then
        Exit Sub
Else
Dim oWindow
Set oWindow = CATIA.ActiveWindow
'create text file
sPath = "C:\Temp"
sName = "\Points_coord_for_" & oWindow.Caption & ".TXT"
sFile = sPath & sName
Dim oFileOut 'As File
Set oFileOut = CATIA.FileSystem.CreateFile(sFile, True)
Dim oStream 'As TextStream
Set oStream = oFileOut.OpenAsTextStream("ForWriting")
  Dim mySelection as Selection
  Set mySelection = Catia.ActiveDocument.Selection
  Dim Selection as integer
  Selection = mySelection.count
   oStream.Write ( "Point_name" & ";" & "X-Coord" & ";" & "Y-Coord" & ";" & "Z-Coord" & Chr(10))
  Dim I as integer
  Dim oPointCoord(2) as CATSafeVariant
  Dim oSelElem as Object
  For I = 1 to Selection
   Set oSelElem = mySelection.Item(I)
   oSelElem.Value.GetCoordinates (oPointCoord)
   text = oPointCoord(0) &  ";" & oPointCoord(1) &  ";" & oPointCoord(2)
 oStream.Write (mySelection.Item(I).Value.name &";" & oPointCoord(0)& ";"& oPointCoord(1)&";"& oPointCoord(2) &";" &Chr(10))
   Next
  oStream.Close
 End If
End Sub
Fernando
Hello Fernando,
Already tested your code,
Instead of selecting the point one by one, I want it to run automatically.
The geometrical set also has another item in there (circle and line)
or can you point out what is the problem in my code?
Hope you can advise.
Thank you
thanks for the feedback.
my problem is to search for sub geometrical set. if all the point in main geometrical set, my code can capture the points.
how to search for all geometrical sets?
can you point out how? apparently when i'm using hybridbodies, it will only capture main geometrical set.
thanks in advance
Use
Code:
[aqua]<html>[/aqua]
Sub CATMain()
Set partDocument1 = CATIA.ActiveDocument
Set part1 = partDocument1.Part
Set hybridBody1 = hybridBodies1.Item("Geometrical Set.1")
GetAllChilds( hybridBody1 )
End Sub
Function GetAllChilds( oParent )
		MsgBox oParent.Name & vblf & oParent.HybridBodies.Count, ,oParent.Name
		If (NOT(oParent.HybridBodies.Count = 0)) Then
			' Loop if it has more than one item inside it
			Set oChild = oParent.HybridBodies.Item(1)
			GetAllChilds( oChild )
		Else
		End If
End Function
[aqua]</html>[/aqua]
Maddy
@maddy
your function works! thanks!
@fernando
i think i get the idea, will try work on it later
With a small modification, as I said.
Code:
Sub CATMain()
Dim iAnswer
iAnswer = MsgBox ("Macro will select your points" & Chr(10) & "Click OK to continue or Cancel to EXIT", vbOKCancel)
        Exit Sub
Else
Dim oWindow
'create text file
sPath = "C:\Temp"
  Dim I as integer
  Dim partDocument1 As Document
Dim selection1 As Selection
Set selection1 = partDocument1.Selection
selection1.Search "CATPrtSearch.OpenBodyFeature,all"
Dim selection2 As Selection
Set selection2 = partDocument1.Selection
selection2.Search "CATPrtSearch.Point,sel"
  Selection = selection2.count
   Next
  oStream.Close
 End If
End Sub
Fernando
@fernando
thank you so much for the example.
regards
nmz
