dgallup
Automotive
- May 9, 2003
- 4,708
Controlled Radius - creates a tolerance zone defined by two arcs (the minimum and maximum radii) that are tangent to the adjacent surfaces. Where a controlled radius is specified, the part contour within the crescent-shaped tolerance zone must be a fair curve without flats or reversals. Additionally, radii taken at all points on the part contour shall neither be smaller than the specified minimum limit nor larger than the maximum limit.
My question is can a controlled radius ever be produced by single point turning? No matter how fine an increment the tool moves in it always leaves a small spiral tool mark. I think this constitutes a reversal in the surface. You may have to examine the part under a microscope but if I see single point turning marks I don't think it meets the definition of a controlled radius.
