alaska12345
- Dec 8, 2011
- 9
I have made a simple model of steel seet with solid elements. U can see pictures below. The model is subjected just to tensile load from one side (concentrated force at reference point). I use Static General ON.
What i need to get? For example the specimen is loaded with force 230kN. I want to make any graph or a table with data which show me max stresses at every of two lines (look at pictures!) when the force was 10kN, 50kN, 80kN, 170kN and 230kN. Stresses at lines should be taken just from surface area.
How i can do it? Using path? But how to create a graph or table?
F. ex.
-X axis: increasing concentrated force (from 10kN till 230kN)
-Y axis: max from stresses at line 1 and the same for line 2.
Please, give me some clues.
Thank You on advanced!
Aga
F. ex.
Aga
