Hi all,
I try to change the default macro of Catia to link the test on title block with the property of catpart.
I can not link the name of the material of catpart with a text.
I copy a part of code:
If ProductDrawn <> Nothing Then
Texts.GetItem("TitleBlock_Text_EnoviaV5_Effectivity").Text = ProductDrawn.PartNumber
Texts.GetItem("TitleBlock_Text_Title_1").Text = ProductDrawn.Definition
Texts.GetItem("TitleBlock_Text_Title_2").Text = ProductDrawn.Nomenclature
Dim ProductAnalysis As Analyze
Set ProductAnalysis = ProductDrawn.Analyze
Texts.GetItem("TitleBlock_Text_Weight_1").Text = FormatNumber(ProductAnalysis.Mass,2)
End If
Can you help me to insert on "TitleBlock_Text_Title_2" the name of material? please
Tahnks in advance
End If
Tahnks in advance
