I have been tasked with designing a wall to prevent a tanker truck from sliding off the back of a unloading pad. The pad and the wall will be separate structures.
The design criteria is for a 80k truck going 10 mph and losing control due to icy conditions.
I was looking at using AASHTO table a13.2-1 for the impact force, however this is based on a 80k truck moving at 50mph.
My first thought is I could conservatively scale the 175k load by 1/5 (knowing that the actual force should be based on the velocity squared and not linear).
Is this a reasonable approach? or does anyone more familiar with the AASHTO code know of a better approach?
Thanks for any input.
-JD
-JD
