  • Congratulations waross on being selected by the Tek-Tips community for having the most helpful posts in the forums last week. Way to Go!
Can't get datum symbol to attach to the midpoint of a hole dimension...
Jerry,
I am using NX 8.5 to create the datum symbols. I noticed in my copy of NX 7.5 the attachment point is in the center of the leader. It's NX 8.5 that is attaching the datum symbol to the end of the leader. Are you using 8.5?
Do you know of a way to switch the attachment point from the center to the end of the leader. Or more importantly from the end back to the center?
Mike...
Using NX 8.5, I can't get it to attach to the center of the dimension stub. It appears that it is going to work; but when I click for the datum placement, the leader shifts over one way or the other. You might want to open an IR with GTAC.
