PLIST IGNORE MEMBER 2
flam04
Industrial
Aug 28, 2013
21
I'm trying to find PLIST IGNORE MEMBER for NX9
The 'PLIST_IGNORE_MEMBER' attribute is created automatically for all Components in an Assembly. Just select the Component of interest, press MB3, select Properties -> Attributes and in the 'Unset' Category you should find the 'PLIST_IGNORE_MEMBER' attribute. Just select it, set its value to 'Yes', hit return and then OK.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
When should this command be used?
What for?
MZ7DYJ
It is used when you don't want a component to be included in the parts list that is on the drawing.
Maybe you are showing a part on the drawing for reference only.
