NX 9 available Icons?
PDW
Automotive
Oct 13, 2010
110
thread561-278921
To Mr. John Baker,
Following above thread I was able to download the NX7,5 Icons.
Would it be possible to do the same for the NX9 available Icons?
I would really appreciate this...
Best regards,
Pascal DW
OK, do you have a GTAC 'Webkey ID'? If so, I can load them onto the GTAC 'scratch area' and you can then download them from there (note that this is the ONLY mechanism that I'm allowed to use to transfer these icon files to users).
What size Icons do you want; 16, 24, 32 or 48 pixel icons?
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Hallo John,
Thank you for the quick respond.
Yes, i do have a GTAC Login, so no Problem for me.
Could be the 32x32 as the 48x48 icon size.
[thumbsup2]
Hi John...
I have some interest in those files as well. I do have a Webkey.
Many thanks in advance..
Ronald van den Broek
Mechanical Engineer
Cad Environment Coordinator
Wärtsilä, Propulsion Services
NX8.5.3 / TC9.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP EliteBook 8570W Intel(R) Core(TM) I7-3740QM CPU @ 2.70GHz, 16Gb Win7 64B
OK, I've uploaded both the 32 and 48 pixel icons to the GTAC 'scratch' area. The file names are:
NX_90_bitmaps_32x32.zip
NX_90_bitmaps_48x48.zip
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Super,
Got them...
thx
Hi John,
Can you provide the latest Icons. I want to use in my block styler dialog.
Thanks in advance,
Mukundh
Which sizes are you looking for? Note that the latest libraries that I have are the NX 9.0 bitmaps. Will that be good enough?
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
What size do you want; 16, 24, 32 or 48 pixel icons?
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
OK, I've uploaded both the 16 and 32-bit pixel icons to the GTAC 'scratch' area.
The file names are:
NX_90_bitmaps_16x16.zip
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Sorry, John, I'm late, the files are no longer in the scratch area, could you please upload them again?
Frank.
OK, the files have been uploaded. Same detailed info as before.
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Sorry again John, I have tried to download the files from scratch directory but no success. The system says:
"The file you are attempting to download could not be found. Please be sure to specify the full and exact filename. Do not attempt to use wildcards or any other shortcuts as these are explicitly checked for and denied by default."
I have tried with:
NX_90_bitmaps_16x16.zip and NX_90_bitmaps_32x32.zip
Frank.
Frank,
NX_90_bitmaps_16x16_2.zip
NX_90_bitmaps_32x32_1.zip
HTH,
Joe
Hi John,
Could you make these available once again ?
NX 9.0.3.4
NX 10.0.1.4 (Testing)
Windows 7 64 (Windows 8.1 Tablet)
OK, I've uploaded to the GTAC 'scratch' area all four NX 9.0 icon sets:
NX_90_bitmaps_16x16_6.zip
NX_90_bitmaps_24x24_2.zip
NX_90_bitmaps_32x32_3.zip
NX_90_bitmaps_48x48_1.zip
They should be there for a couple of days.
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Thank you John,
NX 9.0.3.4
