Parts list question
bafio
10
From the previous thread
Link
to give an appropriate title to the thread I will continue here.
After watching the video of PhoenNX PLM, I became aware that we have much to learn.
All my "Seed Parts" have an attribute called "Code" and I set in all seed parts
Code = <W$=@$PART_NAME>
In parts list I have a column for the attribute "Code" but when I update parts list the column Code remain empty.
I done this because generally the code and the part name are the same.
Sometimes however, the Code is only part of the part name and some other the Code is completely different from the part name.
Accept suggestion
NX7.5 (NX10 in few days)
Maybe it's the "units" of the cell.
Highlight the column and rmc to Style, in one of the tabs you are able to change it to either text, money, decimal inches, and things like that; make sure you have it set to what best works for you.
I am not at work now, so I can't direct you well.
Although it seems to me that none of those voices is applicable to my case, I tried all of them.
I also tested each of them with the option "Evaluate cell as formula".
In any situation, the column remains empty.
With the option "Evaluate cell formula as" the column presents on each row the Dash
Fabio on NX7.5
Well I understand that cannot be done directly in parts list (Code column = <W$=@$PART_NAME>)
Can I automatically get this information in expression? Then NX9 can fill attributes from expression. (No sure about NX7.5)
Thank you
Fabio on NX7.5
Yes, you can create a String Expression set equal to ug_askCurrentWorkPart() which will give you what you want. Note however that this expression will not automatically update but will require at least one manual update for every change in the Part file name.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
