Flexible chain with NX8.5 1
PSI-CAD
Computer
Feb 13, 2009
997
Here is my assembly
download.aspx
PRO/E seems to be able to simulate the flexible chain assy.
Do I have to use deformable component to get the result ? and how ?
Find herewith the test assy
I need to constraint the
download.aspx
holes and the slot
Thanks in advance for your help
Didier Psaltopoulos
No, deformable component is not design for this purpose.
The best exemple of use of this feature is a spring.
Your components are rigid, it's only a matter of assembly constraints.
Look for the "motion" application, you should be able to achieve what you want.
"My english is bad ? That's why i'am french."
Using the standard assembly license.
When everything is well constrain, then, your chain link will move.
But, I don't know how to force them to be aligned on the ground or how to give them a "real" behavior.
I get it to update quite nicely, it doesn't behave like a true cable chain since the real thing cannot bend in the "wrong direction" but apart from that it updates.
Anyhow
I removed the constraints in the "sub ass" between the start-end of the chain. ( 2 constraints, parallel and distance deleted.)
In the "assy" i selected the upper end of the chain , RMB - Override position.
Then constrained the upper end to the plate.
After moving the "plaque", i need to select one of the links in the middle of the chain RMB - Move : drag it into a better position.
I have a video showing the complete operation, but it's 7.6 Mb, so i'm not sure if i should upload.
leave a reply if you want the video.
Tomas
Toost,
I think the file size limit for engineering.com (the attachment link below) is 20 MB. Your file should upload fine.
www.nxjournaling.com
Here’s the video of the cable chain.
It’s captured using Jing by Techsmith.com ( freeware) it is in Shockwave Flash format. ( .swf)
Save the file to disc, it's compressed in 7zip. extract and open it with Internet Explorer. ( Do not use a “video player”, it will not work.)
Tomas
 http://files.engineering.com/getfile.aspx?folder=422a371c-ffa3-4059-b7f3-5bce9f1c435d&file=didier.7z
Good.
Beside that, do you like the "assembly constraints" ergonomy ?
Do you find easy to locate / repair / modify a constraint ?
Hi Stéphane,
I like assembly constraints ergonomy. Even I remember the easy way to find them with mating conditions in NX4, the following process is a good solution to explore the assembly:
download.aspx
And the result
download.aspx
Or you can also use the new constraint navigator
download.aspx
Don't hesitate to contact me directly in france [wink]
Didier Psaltopoulos
