I've got a pile supported grade beam that is predominantly loaded in torsion. From a constructability perspective, I desperately want to use stirrup arrangment "B" in the sketch below. However, in thinking through the load path using strut and tie logic, I can see no way to avoid using stirrup arrangement "A".
