It's a firewall, so a fairly complicated surface. It tells me "the offset distance might be greater than the radius of curvature of the face or the offset face might intersect itself." Is there any other way for me to extrude the part? It doesn't have to be all that thick either, but I need a workable solid.
Also, "Extrude Facet Body" didn't work for me in the first place for some reason, it doesn't give me errors, previews, anything.
After creating the 'zero' distance 'Rough Offset' of the original faceted body, create a second 'Rough Offset', referencing the surface created in the first operation, with the distance set to the desired thickness of the final model. Now create 'Ruled Surfaces' between the outside edges of the first sheet body and the outside edges of the second sheet body and then 'Sew' them together.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA Siemens PLM: UG/NX Museum:
The shape and curves of the sheet made it difficult to use ruled surfaces, but I used "pull face" then "copy face" and sewed it together making a solid body.
Thanks for the help!
