I know this question is difficult to quantify, but how much steam should escape from the air gap on an drip pan elbow? I have a 6" valve rated for 23,468 lbs/hr that lifts at 25 psig and fills a small 25'x30' room with steam when it lifts. It is enough to set off the smoke alarm. It only serves a flash tank that harvests low pressure steam and sends it back into a 15 psi system. The problem occurs when there is a power outage or other issue on the load side of that low pressure system. The steam has no where to go, but the high pressure condensate entering the flash tank is coming from multiple sources. It keeps coming and there is no where for the low pressure steam to go except through the relief valve.
What is reasonable? The vent line is I believe a 10" that goes up probably 200 equivalent feet, including 7 stories up and out the roof. Could that be my problem? Too much back pressure?
More fundamentally, why do I need the gap? There is a drain on the bottom of the elbow to allow any condensate or rain water to drain out. If I didn't have the gap, there would never be any water in the pan itself. The connection through the roof is sealed, so no water is coming back down on the outside of the pipe.
Thanks for your help.
