ajk1
- Apr 22, 2011
- 1,791
It has been suggested that steel beams of floors supporting masonry partitions be designed for a service load vertical deflection limit of span divided by 500 or 600 or perhaps even more stringent, to minimize the possibility of the partition cracking due to beam deflection. This would be under specified live load plus load applied after the partition is built, as well as the self weight of the partition.
Where is that limit given? Is it in the National Building Code of Canada or its User's Guide, or CSA S16.1? I can't find it, but I don't have the latest versions here at home. Or if not there, then where? Perhaps in NRC notes or an American publication?
