hi there, i am qualifying the welding procedure for A333-Gr.6 for welding of fabrication in accordance with ASME B31.3. I have some concerns needing your advice for the following cases:
#1: the design temperature - 39 degree C, so does PQR need to do impact test?
#2: the design temperature - 20 degree C, so does PQR need to do Impact test?
#3: the design temperature - 43 degree C, the base metal and consumable already was impact tested mentioned in the its certificate, does PQR need the additional impact test?
