Guys,
I'm trying to use a downturned slab edge to support a kneewall and glazing. I'm considering the linear reaction from the glazing (negative wind load) to cause a point load at the top of my kneewall, which in turn creates outward shear and overturning about the outer edge of my down turned slab. I don't have enough concrete in my footing to counteract the overturn. Can I use my slab reinforcing, hooked into the thickened edge of the slab, as a tie to counter the overturning? Basically like a tie-rod.
