FilippoT
- Oct 13, 2013
- 34
According to API RP 2201, in case of an hot tapping activity, welded fitting and hot tapping machine shall be pressure tested before the cutting execution.
the test pressure is suggested to be at least equal to the internal operating pressure of the run pipe, maximum 1.1 the internal pressure. Usually it is best practice to check if such calculated test pressure is lower than the maximum allowable external pressure of the run pipe.
What if such max external pressure is lower than the calcualted test pressure? is there any issue to reduce the test pressure to a lower value in order to avoid run pipe collapse?
If i reduce the test pressure, then can i keep the current operating pressure after hot tap?
