Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Thanks for creating this site - I expect to be visiting it often as I continue to try to grow my bag of tricks!..."
Geography
bpss (Mechanical)
31 Jan 03 12:32
I have a molded nylon 6 bracket approx. size 7x25x5mm. Can someone suggest alternative materials which could use the same tooling (similar shrinkages) but is a little more flexible?
Thank-you for your help.
TheAnswerGuy (Materials)
31 Jan 03 12:54
You might want to check out Polyurethane?
patprimmer (Publican)
31 Jan 03 20:26
Have you allowed the nylon to moisture condition to a reasonable ballance with the atmosphere. It's dry fleural modulus can be up to 3 times as high when dry vs conditioned.
If the nylon is conditioned, try LDPE modified nylon 6, which is sold as a cheap toughned grade, or try MDPE.
Some rubber modified PP, such as auto bumper grades might be of interest
It depends a lot on why nylon was chosen in the first place, and what other properties you need.
Also, mould shrinkage is not quite that simple. Two different materials might have similar shrinkage in one mould, but different shrinkage to each other in another mould
pat
plasticsguru (Materials)
17 Feb 03 10:53
RTP 200 A HI is a impact modified 6 and should give a more flexability and at the same time use your current tooling. You can call RTP 1-507-454-6900 to get more information
Close Box
Join Eng-Tips® Today!
Join Us             Close
