One of the fields in my title block is the mass of the part, stored in a configuration specific custom property.
Unfortunately SW changes the units based on what I select in the options, i.e. if I select mm the mass will be shown in grams, if I select inches the mas will be shown in lbs, if I select metres the mass wil be shown in kg and so on.
The number of decimals changes also according to what I set in the options.
In my title block I need the mass shown in kg with three decimals. But I will also like the part to be left in whatever units I last used. Anyone has a suggestion on how to accomplish this thing?
Andrew
Andrew
