For generic rubber or cloth reinforced gaskets in 125 - 250lb flanges, where would I locate the appropriate fastener torque specs? These are being pulled against a cast pump flange (flat or raised face)
Current spec appears to be "As tight as the impact gun makes it"
Any help would be greatly appreciated! Email direct if you have a spreadsheet or chart
Keep the wheels on the ground
Bob
showshine@aol.com
Bob
showshine@aol.com
