Bacvar
- Apr 22, 2004
- 22
Hello all,
I have come across a problem when re-using assemblies. I have this assembly which is complete with 75 parts & 8 sub-assemblies. I need to use this assembly 4-6 times within a layout (main assembly/product). This assembly (that I need to re-use) will basically stay the same; however, a few things will change within some of the parts (length, height thickness). But, in order to keep these assemblies unique from one another I need to rename each part file name and each part property name in order to stay clear from any ‘part conflict name’ or identical part names over-writing one another.
Is there anyway of getting around this problem? Is there some way to rename all part names and property names by using some kind of “Save all as” command, saving all with a suffix/prefix etc…?
