Member Login
HANDLE
PASSWORD
Remember Me
Forgot Password?
E-mail*
Handle
Password
Verify P'word
Partner With Us!
Partner Button
(Download This Button Today!)
Member Feedback
"...Thank you. I have never said it, but you have a great web site. It is of immense help...."
Geography
notnats (Mechanical)
8 May 04 21:17
Here is a paradox that automotive engineers can solve for me.
Because a tyre is slightly flattened at the point of contact with the road, the height of the axle above the road is less than the radius of the tyre.
The driving torque of the axle produces a forward force at the point of contact of T/r, where r is the height of the axle above the road. OK.
But when the wheel turns a full 360 degrees, the distance the vehicle moves is 2piR where R is the unloaded radius of the tyre. While the wheel is rotating, the effective force would appear to be T/R.
Is the driving force greater when the vehicle is stationary than when moving?
If not, what happens to the extra rubber in the circumference?
I realise this is trivial, but I have worried about this now for some years, (not very hard though)
Jeff
Check Out Our Whitepaper Library. Click Here.
GregLocock (Automotive)
9 May 04 5:45
"But when the wheel turns a full 360 degrees, the distance the vehicle moves is 2piR where R is the unloaded radius of the tyre. While the wheel is rotating, the effective force would appear to be T/R."
No it isn't.
1) In order for the tyre to create grip it has to move relative to the road surface.
2) The tractive force is t/r2 where r2 is the laden radius, not the unladen.
Cheers
Greg Locock
9 May 04 6:03
Ok Greg
Then does the vehicle move 2piR or 2pir2?
Does the tyre have to move relative to the road surface to create grip? Railway wheels don't. (The rail and wheel have the same elasticity and presumably do not move relative to each other at the contact patch)
I can see that the tyre and the road must move relative to each other to solve the paradox, or perhaps the tyre structure (including the tread)deforms while the contact patch retains its momentary shape.
Jeff Stanton
Helpful Member!NormPeterson (Structural)
9 May 04 11:48
Distance traveled is somewhere in between what the free radius and the loaded radius predict.  There's a derivation given in "Mechanics of Pneumatic Tires", that identifies the tread as being compressed in the contact patch and also over the zones immediately before and after the contact patch.  It goes on to talk in terms of effective radius and effective deflection that differ from the loaded radius and actual deflection respectively.  And it mentions that very little longitudinal slip occurs within the contact patch (assuming no acceleration/braking), hence there's little wear under conditions of rolling in a straight line.
Eventually the discussion gets around to providing some experimental data, with the actual distance traveled measured for a bias tire given at 96% of what the free radius predicts but the loaded radius being only 94% of the free radius (yes, this dates my reference material somewhat).  For radials, it gives 98% distance traveled with the loaded radius being only 92% of loaded radius.  Data for more recent tires may differ in the specific percentages, but I'd certainly expect the general relation to hold.
Norm
9 May 04 17:39
Thanks Norm. My "thought experiments" ran along those lines. Nice to see some data,
jeff
SusTestEng (Automotive)
10 May 04 16:46
There is a very easy way to see "what happens to the extra rubber".  Just push down on the tread of a flat, or unmounted tire, and observe the the gap between the individual tread blocks.  You will see that the gap in the tread becomes smaller as a flat "contact patch" is created by you pushing a section of the tire flat.  So if you were to measure each gap between the blocks when it is round, and when it is flat, you will see where the "extra rubber" went...it just got closer together.
EnglishMuffin (Mechanical)
29 May 04 14:09
Just seen this thread - thought I would make a comment:
"Does the tyre have to move relative to the road surface to create grip? Railway wheels don't. (The rail and wheel have the same elasticity and presumably do not move relative to each other at the contact patch)".
Actually, a railway wheel does a very similar thing, although the effect is very small. The rail and wheel do not have the same "elasticity" since they are different shapes, although of course the E values are effectively the same. Relative sliding within the contact patch is one of the sources of rolling resistance, which you can read about in texts on ball bearing analysis for example.
30 May 04 8:32
Fair enough English Muffin, but is relative movement necessary to create grip? Or is it an unwanted effect of grip?
Jeff
30 May 04 9:16
Grip is created by several mechanisms, off the top of my head:
1) chemical grip - bonding between the rubber and the road - doesn't need slip
2) cogging grip - intermeshing of asperities on the surface of the tyre and road - doesn't need slip
3) hysteresis grip - deformation of the rubber as it drags over the surface needs energy, so it need sa force and a velocity. Needs slip
I don't know the relative proportions of those in a given situation, but it is worth pointing out that standard tyre results are presented with slip on the x axis - implying that slip is a very important factor.
Cheers
Greg Locock
30 May 04 15:54
No, although it may well be a contributory factor, you do not have to have relative motion to produce grip. For example, if you had two steel rollers of identical diameter pressed against each other, with parallel axes of rotation, you would have no significant relative sliding in the contact patch, but you would still have grip. You would also still have some rolling resistance, stemming from the internal hysteresis produced by the internal cyclic deformation of the rollers, although it would be small. But elastomers behave rather differently from steel objects - for example, friction is no longer independent of surface area - and spinning dragster tyres produce more grip than non spinning ones. But this particular aspect of the subject is probably better understood by Mr. Locock, in view of his automotive experience.
30 May 04 16:44
OK, actually, after consulting my "extensive" library (grin), I find that I actually do have a book which goes into all this - the increase in friction of elastomers with sliding speed, the pressure distribution on the contact patch of rubber tyres under braking and accelerating conditions etc etc. It is called "The Friction and Lubrication of Elastomers", by D.F. Moore. The same guy has also published an even more relevant book called "The Friction of Pneumatic Tyres", but I don't have that one. I can't find either of them on Amazon or Abe Books, so I guess it doesn't help much - there is too much to reproduce here.
31 May 04 4:24
Thanks Greg and EnglishMuffin. Interesting and productive replies. Mind you, I only asked the questions out of idle curiosity, and got more than I expected.
Jeff
BillyShope (Automotive)
31 May 04 21:53
One last thing: When writing a program to calculate acceleration performance, it's tempting to use the wheel revolutions per mile figure in the calculation of thrust. This would be an error, of course, but at least one of the "big 3" has included this small error for many, many years. In fact, I'm only assuming that it was eventually "caught" and eliminated.
idano (Automotive)
3 Jun 04 14:25
dont forget about tire roll out (circumfrence) increases due to centrifugual forces at higher speeds.
3 Jun 04 15:38
Very little with radial tires, but considerably with bias ply. About 0.2 wheel revolutions per mile per mile per hour, as I recall. (It's been a while.)
Start A New Thread
Promoting, selling, recruiting and student posting
are not allowed in the forums.
Posting Policies
LINK TO THIS FORUM!
(Add Stickiness To Your Site By Linking To This Professionally Managed Technical Forum)
TITLE: Automotive suspension engineering Forum at Eng-Tips
URL: http://www.eng-tips.com/threadminder.cfm?pid=800
DESCRIPTION: Automotive suspension engineering technical support forum and mutual help system for engineering professionals. Selling and recruiting forbidden.
