how to get hidden and center lines to show in paper space
mrspetos
Industrial
May 19, 2004
42
the hidden and center lines are visible in the model space, but when i switch to paper space to fit it to my title block they are all solid lines. any help would be appreciated.
fyi... it will happen again at some point and a regen might not work.. play w/ you "ltscale" setting match them to you viewport zoom factor.
Actually, it kind of depends on what you want to do. If everything will be the same scale in paperspace, then you can set your "ltscale" to whatever scale you are using (96 for 1/8" for example) then make sure your "psltscale" is set to "0" (for off). If you have multiple viewports at different scales, or you just don't want to figure out the "ltscale", you can set it to "1" and then set the "psltscale" to "1" (for on) and all of your lines will appear correctly in paperspace, no matter what scale they are at. They will all look the same. The only down side, when you go back to model space, they will not appear correctly.
turning my psltscale off solved my problems. this is a great place, thanks for all the advice.
