Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...This site is awesome!...Things I have been trying to figure out for weeks, I got the answer in hours!..."
Geography
TerryB (Mechanical)
25 May 04 5:32
We are running a natural gas fired thermal oxidiser to destroy solvent laden air from coating process. The solvents include methanol, acetone, THF, MEK, MIBK etc.
Gas consumption is extremely high and we are trying to optimise temperatures at flue stack and oxidation to maximise efficiency.
Has anybody done this or similar and would welcome sharing experiences ?
Terry
CESSNA1 (Mechanical)
4 Nov 04 18:07
TERRYB:
I am assuming this is part of a site cleanup and is probably part of a vapor extraction system.  Is it or are you doing something else?
The regulatory agency should have a minimum stack temperature for the oxidizer.  This minimum is based on the residence time and the items being burned. I suggest you contact them.  Somewhere around 1000 -1500 deg F sticks in my mind, but I am not sure, it has been many years since I have done this.
Out of curiosity, where are you located
Dave
davekerrigan (Mechanical)
22 Feb 05 14:16
Terry I design thermal oxidizer and would like to help.  First of all I need to know what type of oxidizer you are currently using?  Recoup, Regen, or DTO.  Regens are the most efficent (up to 95%) but there are different styles; poppet valve, rotary valve, flapper valve.  Typically in the printing industry or coating process we use 1400-1500 for a 98% destruction.  If you do not need this high destruction effiecency you could take this down lower.  There is a catch, you will need to run at the temp you were approved at.  If you fill me in on your oxidizer I would be happy to help.
David K.
Close Box
Join Eng-Tips® Today!
Join Us             Close
