True Position inspection
bootnreboot
Aerospace
Nov 15, 2010
3
Does anybody have a source showing inspection methods for determining True Position ?
I teach GD&T classes and am always asked..."How are parts inspected for true position?"
I know there are many ways to check this but i can not find actual examples of how a virtual condition fixture is being used, CMM or other gauges.
Thank you in advance for any help you can send my way.
Try a cross link for the GD&T forum
The best book I've found on GD&T is this:
I think this would normally be done with a Faro or Romer arm.
But True Position can be inspected with normal linear measurements. True position is just a different way of allowing tolerance. Measure the position of the hole in the normal X & Y dimensions, the square root of [(error in x)^2 + (error in y)^2] is the amount of true position tolerance used.
Example:
-True position within .060 inches
-Nominal Position is (1,3), Actual Position is (1.023,2.981)
-Square Root[(.023)^2 + (.019)^2] = [0.000529 + 0.000361]^.5 = .0298
-Of the .060 inches of available tolerance, you have used .0298
If you're referring to a fixture, it depends on the callout - Maximum Material Condition or Regardless of Feature Size.
