Justice100
Chemical
- Jun 18, 2008
- 51
For API 2000 the relief rates are defined as Nm3/h of air. When looking at for example thermal inbreathing - My tank is blanketed with fuel gas with a PCV that will open up at 0.1 barg to let fuel gas in.
Once I have the required flow rate in Nm3/h of air how to work out fuel gas consumption? Is it Nm3/h of air = Nm3/h of fuel gas? Or should I use Graham's law? Or something else?
