CuriousElectron
- Jun 24, 2017
- 189
Greetings All,
What is typical ratio between skW and rated kW of a gas generator? I know that gensets are capable of providing higher starting kVA for motor starting, but do they also provide higher skW for limited time? What is the limiting factor here.. is it the temperature rise on alternator windings(thermal)?
Say a gas generator is rated for 100kW, would it be capable to provide 150skW for short duration to start a motor load?
Thank you,
EE
Thank you,
EE
