In need of a four cylinder head model (technical drawing)
Jonut459
Student
Jan 3, 2025
1
Hello, might seem a weird request, but I am in need of four cylinder head DOHC model. I have to do it on a paper for a university project and I really need a starting model. Could not find anything on internet yet. In need of the cross section view (valves, valves spring, tappets, camshaft etc), bottom view (valves, oil and coolant passages etc) and right/left side cross section.
Thanks a lot.
For your DOHC cylinder head model, try searching on platforms like GrabCAD or Thingiverse for 3D models. You can also find detailed diagrams in automotive service manuals or educational resources like MIT OpenCourseWare. If you can’t find what you need, consider contacting a CAD designer or technical illustrator for a custom solution.
