How to properly show compound angles of a feature using GD&T?
Gaganaut06
Aerospace
May 2, 2023
21
I have a drawing of a fitting which connects to a tube at a compound angle of 30deg and 45deg. Is this the correct way to show this (attached)
  • compound angle clarification.pdf
The views are fine, but the angularity tolerance is ambiguous as it is not clear which feature it applies to - is it the OD or the ID of the tube?
You should attach the angularity tolerance to the relevant size (diameter) dimension, and if you would use a single angularity tolerance, in view A only with a diameter symbol, you could create a single cylindrical tolerance zone for the axis that would control the compund angle instead of having two different requirements for the same axis (each time limited by a different parallel-planes tolerance zone).
To establish an angle one needs references. You have only the reference to [A], so you need one more reference to control clocking relative to whatever is important. You have suitable dimensions, just no references defined for tolerance for clocking.
Hi, Azeemsha:
As 3DDave indicated, you can't have a dangling BASIC dimension (30 degrees in this case). BASIC dimensions must be traced back to its datum feature(s). You can only use a dangling dimension if it is a size dimension for feature of size.
Happy New Year!
Alex
Thank you, jassco, 3DDave, Burunduk, for your clarifications. I have attached the updated drawing. Hope this is correct.
Happy New Year
  • compound angle clarification 2.pdf
Hi, Azeemsha:
The print looks Ok as long as you know that this feature with dimension dia. 17 is not located. You will also need a size tolerance for this dimension.
Best regards,
Alex
Hi, Azeemsha:
Best regards,
Alex
Is it wrong to assume that OP is expecting standard-size tubing whose diameter won't really be controlled by the manufacturer of this part?
Hi, Flying Whale:
Those 30 and 45 degrees BSC angles only control orientation. They do not locate the feature.
Best regards,
Alex
I see now that you were talking about the location of the part, I misunderstood it as if you were saying the 17mm diameter dimension needed tolerance.
It is not location of the part. I meant relocation of the cylindric feature in the part.
Best regards,
Alex
