  • Congratulations Toost on being selected by the Eng-Tips community for having the most helpful posts in the forums last week. Way to Go!
Non-linear tire vertical stiffness pacejka2002
VojtechBrychta
Automotive
Mar 1, 2024
7
I'd like to ask you, do you know to introduce non-linear vertical stiffness to 2002pacejka tire model in A/Car? There is just a single number in all tire examples in Adams and I'm unable to find any parameter which could influence it. On the other hand, it seems strange that such a complex tire model wouldn't account for any vertical stiffness variation.
Thank you very much!
Have a nice day,
Vojtech
No, I don't know how to. I suspect the reason is that a MF tire is primarily designed to simulate handling type events. Looking through some test results a linear model seems fine at typical load/psi settings. If the tire is nearly flat a non linear curve would be needed.
I'm working with truck tires and I noticed from the spec sheet of a given tire that the stiffness at 50% load is 20% lower than at nominal load (at constant pressure). I bet this could have an influence on handling as well when it comes to the load transfer during cornering/braking.
Do you know which tire model would be suitable for my application? I'm looking to perform a static roll over test. I don't want to go with Ftire due to a lack of data as well as simulation performance and Fiala seems to have the same problem as 2002pacejka.
Thanks a lot!
Vojtech
I think you'd be disappointed by ftire, at least the version I used gave identical results to pac for handling events (I may have used it wrong, I was interested in impacts, not handling). One approach might be to smooth the Flattrac data and then just interpolate off that, in n dimensions. This makes your tire files rather large but can be quicker than Pac, since essentially you are only doing simple maths.
What data do you have?
I use Ftire for comfort studies, where I find it quite useful. But the simulation time usually goes from seconds to minutes when compared to pacejka which is not acceptable in this application.
I have following data available for the 275/70 R22.5 tire in question:
- Ftire model (derived from the cosine library as we're using a similar tire size)
- Pacejka model (from tire manufacturer, but it's quite limited when it comes to the slip angles etc.)
- Tire spec sheets (basic dimensions and stiffnesses)
So quite a lot of data from which I can derive the vertical and lateral stiffneses necessary for the roll over test. What do you mean by the flattrac data?
Thanks!
Sincerely,
Vojtech
The tire test data. You could try something ugly like using a non linear hub compliance. I'd be surprised if that works.
Another option would be to add your own SFORCE statement to each contact patch which adjusts the Fz at the cp to replicate a softening tire.
