How to read data from ABAQUS during simulation?
TMD1099
Student
Jan 10, 2025
3
Hello Everyone,
In my simulation, I have a RHS column with shell element with reduced integration. There are two steps, 1st is mechanical axial loading and 2nd is thermal loading of the column.
I would like to know if it is possible to read the data such as displacement or reaction forces while the simulation is running?
Thanks in advance.
You can open the output files as they are filled with results. There's also DOF Monitor in Abaqus/CAE that lets you plot selected DOF (displacement of a given node in the selected direction) while the simulation is running.
Thank you for your feedback.
But I want to read this data while the simulation is running. SO let me know if there is any way possible to do that.
Hey there, Have you checked if your simulation software allows for live data output? Also, what specific data are you mainly interested in while it’s running?
Hey,
The software I am using is ABAQUS by DS. That's my question whether it is possible or not. If Yes, then I am interested in Displacement and Reaction forces.
Hey,
Yeah, you can usually access results in ABAQUS while the analysis is running. I think you’ll want to look into using the field output for that. But I’m not 100% sure if it works for both displacement and reaction forces, might depend on your specific setup.
Yes, you can access output files during the analysis. You can even open the .odb file with results in Abaqus/Viewer before the analysis is completed. But it won't be updated live, you have to reload it to see new results.
DOF Monitor is a useful tool for viewing data in real time. You can also use Python scripts to read the information. This simplifies the analysis of the simulation.
