Point Move to Error 1
Xprivate
Aerospace
May 26, 2023
55
hey everyone , i have a surface that i want to correct. So the only way is to move the point to some location in space which corrects the surface. But unfortunately when i try this option Modify>move to > point to location , i am unable to move the point. Instead i get this message on the message box, " could not move point as specified" . can some one help me with this . thanks in advance
Hello!,
Use the MESHING TOOLBOX and use command PROJECT/MOVE POINT : first select the point at the target location, and next select the source point you want to move
Here some examples I have created to explain this new feature of moving points in geometry using the MESHING TOOLBOX in the release of FEMAP V2301 (January 2023), you can visit my blog: https://iberisa.wordpress.com/2023/04/12/femap-v2301-enero-2023/
The same moving points on meshed curves:
Best regards,
Blas.
PD
If not success please post your FEMAP model (*.modfem) here and we will take a look to it, thanks!.
THank you Blas for detailed explanation, this really helped
