Design
Dhlo12
7
what reinforcement details need consideration when there is a change in design?
ex. update concrete wall from precast to insitu ?
This is not the right forum for your question.
Now don't be so lazy; take the time to find an appropriate forum here for your question, re-post it there, and delete this one.
Also, to get any kind of worthwhile answer, you will need to supply far more information.
Well, I think the general structural forum could be the right forum. Though, I also don't think we have enough information to respond with any insight.
The only "precast" walls that I tend to see are tilt up walls. If your design changes from tilt up to cast in place, I think the are some decent changes / simplifications that could save your client money. But, I'm not even certain that's what we're talking about here.
I've done multi-storey apartments with precast walls and HC slabs...
Based on the information provided, I'd have to go with all of them.
To elaborate more on what @phamENG has said, you need every detail that is specific to cast-in-place concrete applicable to your project. Subsequently, you can remove any details that are for detailing pre-cast concrete.
Probably do not design a reinforced concrete structure if asking on a forum "what reinforcing details need to change"? Surely, you aren't the EOR?
