TugboatEng
Marine/Ocean
- Nov 1, 2015
- 11,806
I have an idea that involves using sound to detect the occurrence of certain events in a diesel engine. Specifically, I am looking to "hear" the rocker arm contact the valve stem, the valve closing in the seat, and the opening or the fuel nozzle. I would like to be able to do this through a thin die-cast aluminum valve cover. The ability to measure the frequency of the sound may be beneficial in identifying which event is occuring. However, I will know about when each event does.
The question: Are there any recommendations for sensors to start with?
